Radiation boundary conditions
Dear All!
Hello. Hope you are fine and happy. I am working on a case which is a vertical parallel plates channel. Walls are kept at different constant temperatures. I want to model turbulent radiation heat transfer in this geometery. I wanted to know which boundary conditions i must use. I have to model the medium as participating and I want to change wall emissivities, optical thickness and scattering albedo in order to get results. I wanted to know what the difference between Marshak radiation b.c. and greydiffusive radiation b.c. is. I should assume that walls are gray and diffusive (and also the medium) but I am somehow confused about these b.cs in openFOAM. I would be really grateful if you please help me with this. Thank you very much. Mas |
Could you find a detailed explanation for this? |
Hi all!
·MarshakRadiation (Do not click here if you do not want to learn where to find info on your own!) Code:
Group Code:
Description Code:
Description Code:
find $FOAM_SRC -name Marshak* Code:
find $FOAM_SRC -name greyDiffusive* Regards, Alex |
