Radiation boundary conditions
Old   January 14, 2014, 04:01
Default Radiation boundary conditions
Masoud Ami
MasAmi is on a distinguished road
Dear All!
Hello. Hope you are fine and happy.
I am working on a case which is a vertical parallel plates channel. Walls are kept at different constant temperatures. I want to model turbulent radiation heat transfer in this geometery.
I wanted to know which boundary conditions i must use. I have to model the medium as participating and I want to change wall emissivities, optical thickness and scattering albedo in order to get results.
I wanted to know what the difference between Marshak radiation b.c. and greydiffusive radiation b.c. is. I should assume that walls are gray and diffusive (and also the medium) but I am somehow confused about these b.cs in openFOAM.
I would be really grateful if you please help me with this.
Thank you very much.
Mas
MasAmi is offline   Reply With Quote
Old   February 5, 2015, 08:41
Pedro
pedrojrebelo is on a distinguished road
Could you find a detailed explanation for this?
pedrojrebelo is offline   Reply With Quote
Old   February 5, 2015, 20:50
Alex
zfaraday will become famous soon enough
Hi all!
·MarshakRadiation (Do not click here if you do not want to learn where to find info on your own!)
Group
    grpThermoBoundaryConditions
Description
    A 'mixed' boundary condition that implements a Marshak condition for the
    incident radiation field (usually written as G)
    The radiation temperature is retrieved from the mesh database, using a
    user specified temperature field name.
    \heading Patch usage
    \table
        Property     | Description             | Required    | Default value
        T            | temperature field name  | no          | T
    \endtable
    Example of the boundary condition specification:
    \verbatim
    myPatch
        type            MarshakRadiation;
        T               T;
        value           uniform 0;
    \endverbatim
·GreyDiffusive (Never click here! You could even find useful info...)
Description
    This boundary condition provides a grey-diffuse condition for radiation
    intensity, \c I, for use with the finite-volume discrete-ordinates model
    (fvDOM), in which the radiation temperature is retrieved from the
    temperature field boundary condition.
    \table
        emissivityMode | emissivity mode: solidThermo or lookup | yes |
    \endtable
    \verbatim
    myPatch
        type            greyDiffusiveRadiation;
        T               T;
        emissivityMode  solidThermo;
        value           uniform 0;
    \endverbatim
·GreyDiffusiveViewFactor (You shall not clik! Gandalf dixit)
Description
    This boundary condition provides a grey-diffuse condition for radiative
    heat flux, \c Qr, for use with the view factor model
    \table
        Qro          | external radiative heat flux | yes    |
    \endtable
    \verbatim
    myPatch
        type            greyDiffusiveRadiationViewFactor;
        Qro             uniform 0;
        value           uniform 0;
    \endverbatim
You could even find it inside your own computer!
find $FOAM_SRC -name Marshak*
find $FOAM_SRC -name greyDiffusive*
Enjoy it!
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
inlet boundary conditions newOFuser OpenFOAM 1 January 10, 2013 08:08
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
