April 12, 2007, 05:37 |
Hi all,
I would like to map
Hi all,
I would like to map results from a mesh to another one with the same geometry but different boundary partitions (the number and the names of the patches do not correspond). However I'm not interested in mapping boundaryFields but only the internalFields. I was not able to make mapFields work without the -consistent option. Is there a way for mapping only values on the internalMesh? Thanks a lot Cosimo
Cosimo Bianchini Ergon Research s.r.l. Via Panciatichi, 92 50127 Florence - ITALY Tel: +39 055 0763716 Mob: +39 320 9460153 e-mail: cosimo.bianchini@ergonresearch.it URL: www.ergonresearch.it |
June 23, 2015, 09:49 |
Simon Grützner
Rep Power: 11 |
Hi Cosimo,
did you come up with an answer or a work around to your post? I have a case, where I refined certain regions using refineMesh. If I use mapFields to map field variables of the coarse Mesh on to the refined one, the internal Fields are not mapped. It is just the boundary conditions that are. I dearly hope for a reply. Best regards, Simon |
December 1, 2015, 06:23 |
SM
Rep Power: 15 |
The question in still unanswered!
Is there a way for mapping only values on the Code:
internalField |
December 1, 2015, 06:25 |
Simon Grützner
Rep Power: 11 |
I have not found a way and stopped looking, but am still interested in a solution, of course.
Regards. |
June 14, 2017, 01:38 |
Ambrus Both
I think I found a way to do this. I know it is late for you, but for future reference I leave this here: I use: Code:
mapFields ../../014LuLaw188/baseCase/ -sourceTime 0.05 -mapMethod mapNearest -targetRegion region0 E.g.: Code:
cp ~/OpenFOAM/OpenFOAM-2.3.x/tutorials/lagrangian/DPMFoam/Goldschmidt/system/mapFieldsDict ./system/ Code:
-targetRegion region0 For me the mapping created some nan entries, and some programs cannot deal with this, so I substituted them with 0 by executing the following line in the 0 directory: Code:
find ./ -type f -readable -writable -exec sed -i "s/nan/0/g" {} \; |
May 5, 2020, 06:08 |
Field reinitialization in bynary with mapFields utility
Adriana Ferreira
Rep Power: 7 |
Hello everyone,
The solution of Ambrus worked well for me. In my case, I needed to do a field reinitialization by keeping the internal field and changing the boundary conditions. I had the same geometry with the same mesh refinement but as my files were in binary (to keep the double-precision) I couldn't change the boundaries manually, so the workaround I found was: 1. create the new files (p and U for example) with the desired boundary conditions 2. map the internal field from a previous case according to Ambrus instructions I hope it may be useful if someone faces the same problem as me. Best regards. |
MapFields | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Pre-Processing | 18 | September 28, 2017 11:06 |
MapFields does not work | hartinger | OpenFOAM Pre-Processing | 13 | September 22, 2014 03:14 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
MapFields turbulent pipe flow | anita | OpenFOAM Pre-Processing | 5 | July 3, 2008 23:29 |
MapFields | cpplabs | OpenFOAM Running, Solving & CFD | 3 | February 17, 2008 05:08 |
