CyclicAMI BC preservePatches Parallel Run - again!?!
Like Tree2Likes
  • 2 Post By wyldckat
Old   February 2, 2014, 11:15
Default CyclicAMI BC preservePatches Parallel Run - again!?!
hxaxtma is on a distinguished road
Hi guys,
In my case I am trying to simulate an open couette channel flow with perdiodic BCs:
in: cyclicAMI
out: cyclicAMI
FrontAndBack: slip
bottom: no slip
top: no slip with fixed Value;
decomposingMethod: scotch with preservePatches (in out);
I know I have to keep my cyclic patches in one processor, therefore I used preservePatches (in out); in the decomposeDict File.
If i decompose in 4 cpus the simulation runs.
Checking
grep -A4 in processor*/constant/polyMesh/boundary | grep nFacesprocessors
results for in:
processor0/constant/polyMesh/boundary-        nFaces          0;
processor0/constant/polyMesh/boundary-        nFaces          5143;
processor0/constant/polyMesh/boundary-        nFaces          3474;
processor0/constant/polyMesh/boundary-        nFaces          2150;
processor1/constant/polyMesh/boundary-        nFaces          2320;
processor1/constant/polyMesh/boundary-        nFaces          5143;
processor2/constant/polyMesh/boundary-        nFaces          0;
processor2/constant/polyMesh/boundary-        nFaces          3474;
processor2/constant/polyMesh/boundary-        nFaces          3392;
processor3/constant/polyMesh/boundary-        nFaces          0;
processor3/constant/polyMesh/boundary-        nFaces          2150;
processor3/constant/polyMesh/boundary-        nFaces          3392;
and for out in
processor 1 contains my inlet patch with 2320 faces and my outlet patch with 2320 faces. For out the Output is clear? What are all the other faces for in Output (5143,3392,etc..).
So far so good, but if I try massive Parllelisation on Cluster with 128 cpus my simulation fails with following error: EVEN with 1 CPU! On my local workstation everything is OK
AMI: Creating addressing and weights between 2320 source faces and 2320 target faces
--> FOAM Warning :
    From function AMIInterpolation<SourcePatch, TargetPatch>::checkPatches(const SourcePatch&, const TargetPatch&)
    in file lnInclude/AMIInterpolation.C at line 111
    Source and target patch bounding boxes are not similar
    source box span     : (42.4264 84.8528 10)
    target box span     : (26.0597 76.9991 10)
    source box          : (-42.4264 -42.4264 0) (3.55271e-15 42.4264 10)
    target box          : (-43.7641 -39.1969 0) (-17.7044 37.8022 10)
    inflated target box : (-47.8592 -43.292 -4.09511) (-13.6093 41.8973 14.0951)
[88]
[88]
[88] --> FOAM FATAL ERROR:
[88] Unable to set source and target faces
Where is the problem?
Thanks for help
hxaxtma is offline   Reply With Quote
Old   February 3, 2014, 04:53
I really really need help on this, so any advise would be appreciated
Old   February 6, 2014, 17:48
Retired Super Moderator
Bruno Santos
Quick answer: I don't have time any time soon to look into this, but I think you can find a lot of valuable information on this thread: http://www.cfd-online.com/Forums/ope...using-ami.html
Old   August 31, 2015, 10:41
KateEisenhower is on a distinguished road
Could you please tell how you can use preservePatches in the decomposeParDict File? I looked at the official wiki (http://cfd.direct/openfoam/user-guid...ions-parallel/) but preservePatches doesn't seem to be mentioned.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   August 31, 2015, 17:47
Bruno Santos
Quick answer: Run this command:
echo $FOAM_UTILITIES/parallelProcessing/decomposePar/decomposeParDict
which will tell you the location of the main reference file. For quick reference, this file can be seen online here: https://github.com/OpenFOAM/OpenFOAM...composeParDict
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 14:43
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
