February 3, 2014, 11:05 |
Epsilon Boundary condition
Manan
Rep Power: 12 |
Hello
I am trying to validate a new turbulence model (zeta f) and am solving for epsilon amongst the other variables. The epsilon equation that will be used is the one used in standard k-epsilon model. I want to make use of the formulation, epsilon @Y=0 is specified as 2*nu* sqr(d/dy(k^0.5)). (Turbulence models for Near Wall and Low Reynolds Number Flows: A Review, Patel et. al 1985) I don't understand though how I should specify this in OF? Epsilon @ the wall i.e. at Y=0, is a derivative of k, that is: it is using the value of k @wall and the the value of k @the first node. How do I instruct the solver to use these two values? Please let me know if I haven't made myself clear. Thanks. |
February 3, 2014, 11:43 |
Bernhard
Rep Power: 21 |
Are you aware that the zeta-f0 model was already implemented in OpenFOAM by Mirza Popovac? See: http://openfoamwiki.net/index.php/Si...bulence_models
Also, if you use the epsilon equation from the standard k-epsilon, you don't include any Low-Re modifications, which you would need. Maybe you want to start from the To answer your question: your best change is to start from the epsilonWallFunction, see how the loop over the faces is done and access of the field data, and adjust to your needs |
February 11, 2014, 07:48 |
Manan
Rep Power: 12 |
Hi Bernhard
Thanks so much for your reply. I wasn't aware of the existence of the zeta-f formulation and had written my own code. Fortunately I have Popovac's code to compare it with now. Also, the tip about modifying the epsilonWallFunction is helpful. It did serve my need. |
February 11, 2014, 07:50 |
Manan
Rep Power: 12 |
One question though, when I try compiling Popovac's formulation of zeta-f, using wmake libso, I get the following error message:
/chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileOptions:37: /chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general: No such file or directory make: *** No rule to make target `/chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general'. Stop. /chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:39: /chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general: No such file or directory /chalmers/sw/unsup64/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:40: linux64Gcc47DPOpt/options: No such file or directory make: *** No rule to make target `linux64Gcc47DPOpt/options'. Stop. wmake error: file 'Make/linux64Gcc47DPOpt/objectFiles' could not be created I figured out that there are only a few compilers available in the OF-1.6-ext folder (Gcc45, Gcc46) but not Gcc47. Is there any way to direct $WM_COMPILER to seek Gcc46 (which is available), instead of adding the folder for Gcc 47 in the OF1.6-ext wmake folder explicitly? |
February 11, 2014, 08:12 |
Manan
Rep Power: 12 |
Figured it out. It was as simple as saying:
export WM_COMPILER = Gcc46 Thanks! |
Display Modes | |
Mathematical representation of fixedDisplacementZeroShear boundary condition | Sargam05 | OpenFOAM | 14 | January 11, 2022 07:55 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
No-slip condition for non-resolved boundary layer in open channel banks | Lupocci | Main CFD Forum | 1 | January 17, 2013 04:11 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
