[swak4Foam] funkySetFields over a cellZone
Like Tree2Likes
  • 1 Post By gschaider
Old   February 14, 2014, 06:31
Default funkySetFields over a cellZone
Radu Mustata
r2d2 is on a distinguished road
Dear All,
What would be the syntax of funkySetFields to set a value of a field only on a part of a cellZone of my mesh?
This does not work:
expressions
setProp1
field alpha;
zoneName pipe;
condition " (pos().y < -0.331)";
expression "1";
keepPatches true;
Many thanks in advance...
r2d2 is offline   Reply With Quote
Old   February 14, 2014, 11:41
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by r2d2 View Post
Dear All,
This does not work:
expressions
setProp1
field alpha;
zoneName pipe;
expression "1";
keepPatches true;
This is documented in the incomplete reference guide that comes with the sources and on the original funkySetFields-page (I point this out because it is my impression that the fact that there IS documentation seems to confuse people): you're looking for the zone-function. Your condition would be (if I interpret it correctly) "zone(pipe) && (pos().y<-0.331)"
saumavadey likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   February 17, 2014, 03:33
Radu Mustata
Dear Bernhard,
My fault for being a bit lazy...actually I found it while you gave me the solution.
Many thanks,
radu
Old   July 24, 2021, 03:56
Saumava Dey
saumavadey is on a distinguished road
Hello!
I was trying to set the field for a volTensorField for a particular cellzone the following way:
roughness_channel1
field nRGHo;
zone(channel1);
expression "tensor(0.15, 0.0, 0.0, 0.0, 0.15, 0.0, 0.0, 0.0, 0.0)";
keepPatches 1;
But it doesn't work. The field for the entire domain gets replaced by the given tensor value. Can anyone explain why is it happening?
saumavadey is offline   Reply With Quote
Old   July 26, 2021, 03:49
Assistant Moderator
Bernhard Gschaider
Originally Posted by saumavadey View Post
Hello!
roughness_channel1
field nRGHo;
zone(channel1);
keepPatches 1;
To constrain the cells the cells that FSF manipulates you've got to use a "condition" (it is a bit more typing but sooo much more flexible). The condition can be any expression with a boolean result. In your case something like
roughness_channel1
        field nRGHo;
        condition "zone(channel1)";
        keepPatches 1;
Old   July 26, 2021, 04:07
Saumava Dey
Yes! Got it! It works well.... Thanks a lot!
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
OF-2.2.x: Derived class from cellZone and "undefined symbol error" A_Pete OpenFOAM Programming & Development 6 April 28, 2014 01:53
