modeling a food oven: setting Boundary Conditions |
March 14, 2014, 23:42 |
JuNNioR
Rep Power: 12 |
Hello guys, okay?
I would like to help with the definition of a boundary condition in particular. I'm modeling a food oven and would like to define a condition of entry, much like the condition of total pressure, but do not know the pressure at the entrance and I have known and an average speed of 1 m / s. On output, have a negative pressure of 10 cm H2O and have no concrete information about the speed. How could I set these boundary conditions? It would be reasonable to assume the output to the speed condition zeroGradient? Could please exemplify the use of the boundary conditions. I appreciate everyone's attention and a great weekend. |
March 16, 2014, 12:08 |
JuNNioR
Rep Power: 12 |
No one? Help there.
March 17, 2014, 07:24 |
#3 | |
Joachim Herb
Rep Power: 21 |
You could try the following
For input: U: fixedMean p: zeroGradient For output: U: zeroGradient (or inletOutlet) p: fixedMean (or fixedValue) Quote:
March 22, 2014, 18:51 |
JuNNioR
Rep Power: 12 |
Under the conditions described above, could someone help me identify the errors?
__________________________________________________ _________________________ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { input { type outletInlet; phi phi; outletValue uniform (0 0 0); value uniform (0 0 -1); } output { type zeroGradient; } burnertube { type fixedValue; value uniform (0 0 0); } adiabaticwalls { type fixedValue; value uniform (0 0 0); } } __________________________________________________ _________________________ FoamFile { version 2.0; format ascii; class volScalarField; object T; } dimensions [0 0 0 1 0 0 0]; internalField uniform 0; boundaryField { input { type fixedValue; value uniform 300; } output { type zeroGradient; } adiabaticwalls { type zeroGradient; // Parede adiabática = sem fluxo de energia (calor) } burnertube { type fixedValue; value uniform 1000; } } __________________________________________________ _________________________ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { adiabaticwalls { type zeroGradient; } burnertube { type zeroGradient; } input { type totalPressure; U U; phi phi; rho none; psi none; gamma 1.37; p0 uniform 189180.86;//101325/0.5356+0.5*(1)² } output { type totalPressure; U U; phi phi; rho none; psi none; gamma 1.37; p0 uniform 187349.27;//(101325-0.1*9810)/0.5356+0.5*(1)² } } __________________________________________________ _________________________ I ran the simulation, but deltaT is on the order of 10 ^ -12. Someone could help me? I appreciate everyone's attention. |
[ICEM] Setting up boundary conditions in ICEM for CFX-Pre | mgu | ANSYS Meshing & Geometry | 3 | October 31, 2013 00:00 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
