March 3, 2016, 22:48 |
blockMesh problem
#1 | |
Shahil
Rep Power: 10 |
I am working on a 2D problem (please check the attached image), where a very small heat source is placed inside of the box, with penetrating into the solid. I am facing problems in creating the blockMesh. Please advice if it is the correct way of creating a blockMesh for this case. Also, please help resolving the current error found while running the blockMesh Quote:
blockMeshDict File: convertToMeters 0.001; vertices ( (-505 -400 0) (505 -400 0) (505 150 0) (-505 150 0) (-505 0 0) (505 0 0) (-505 -400 1) (505 -400 1) (505 150 1) (-505 150 1) (-505 0 1) (505 0 1) (-10 0 0) (-10 -10 0) (10 -10 0) (10 0 0) (-10 0 1) (-10 -10 1) (10 -10 1) (10 0 1) (-10 -400 0) (10 -400 0) (-10 -400 1) (10 -400 1) ); blocks ( hex (0 20 12 4 6 22 16 10) (40 80 1) simpleGrading (1 1 1) hex (20 21 14 13 22 23 18 17) (40 78 1) simpleGrading (1 1 1) hex (21 1 5 15 23 7 11 19) (20 80 1) simpleGrading (1 1 1) hex (4 5 2 3 10 11 8 9) (100 50 1) simpleGrading ( ( (0.5 0.5 0.25) (0.5 0.5 4) ) 10 1 ) ); edges ( ); boundary ( maxY { type wall; faces ( (2 3 9 8) ); } minY { type wall; faces ( (1 7 6 0) ); } solidLeft { type wall; faces ( (6 10 4 0) ); } inlet { type patch; faces ( (10 9 3 4) ); } solidRight { type wall; faces ( (1 5 11 7) ); } outlet { type patch; faces ( (5 2 8 11) ); } frontAndBack { type empty; faces ( (0 4 5 1) (7 11 10 6) (4 3 2 5) (11 8 9 10) ); } ); mergePatchPairs ( ); Error in Solver --> FOAM FATAL ERROR: face 0 in patch 1 does not have neighbour cell face: 4(1 7 6 0) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:? #3 Foam:olyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:? #4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:? #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:? #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Aborted (core dumped) Please check attached image |
March 4, 2016, 05:56 |
gereksiz
Rep Power: 11 |
Have you tried to mesh the blocks separately? You may have a ordering error. I remember the error message but I can't recall when I received it.
March 4, 2016, 11:42 |
Rep Power: 15 |
Based on a quick look at your block definitions, I don't see any one block that has all the vertices 1, 7 6 and 0. Double check and see that the vertices that you use to define a face belong to a particular block. Cheers, Antimony |
March 4, 2016, 13:51 |
Shahil
Rep Power: 10 |
Hello guys,
Thanks for your quick advice. I specified the blocks separately and the mesh worked out. The following is what I did: minYa { type wall; faces ( (0 20 22 6) ); } minYb { type wall; faces ( (20 21 23 22) ); } minYc { type wall; faces ( (21 1 7 23) ); } ...................................... frontAndBack { type empty; faces ( (0 4 12 20) (20 13 14 21) (21 15 5 1) (22 16 10 6) (23 18 17 22) (7 11 19 23) (4 3 2 5) (11 8 9 10) ); } -------------------------------------------------- Keeping the rest of the conditions same. Thanks |
[blockMesh] Problem with blockMesh and my shape | TneurolF | OpenFOAM Meshing & Mesh Conversion | 4 | June 25, 2013 13:52 |
Blockmesh problem with more than one block | sven82 | OpenFOAM Pre-Processing | 1 | June 4, 2013 17:08 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
