Precision error when running snappyHexMesh
Old   July 15, 2014, 02:17
Default Precision error when running snappyHexMesh
SirLankyIII is on a distinguished road
Hi Folks
I've been working on a project using OpenFOAM and I've since moved from using Linux to Windows to run some comparative tests. I've found that when I used snappyHexMesh in windows (i'm using OpenFOAM-2.1.x for Win64) I get the following error.
Your current settings specify ASCII writing with 6 digits precision.
Your merging tolerance (1e-006) is finer than this.
Change to binary writeFormat, or increase the writePrecision or adjust the merge tolerance (mergeTol).
I don't get the same error in Linux, and thus far I've been unable to resolve it (changing the write format in any the snappyHexMeshDict does nothing, neither does chaning writePrecision in etc/controlDict and I haven't found a means to adjust merge tolerance).
I understand OpenFOAM isn't designed for windows and to expect problems, but this seems like something small that should be easy to resolve.
SirLankyIII is offline   Reply With Quote
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! dancoz87 ANSYS 17 November 14, 2016 01:10
[snappyHexMesh] SnappyHexMesh in Parallel problem swifty OpenFOAM Meshing & Mesh Conversion 10 November 6, 2015 04:40
Switch from single precision to double precision kk81 OpenFOAM Bugs 0 March 11, 2010 06:14
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 08:08
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
