mapFieldsDict expert wanted!
Hi
I have a simple aerofoil case where I want to split the foil into upper and lower so that I can play with the wall roughness on each side. How do I set up mapFieldsDict to run from a stable solution where the foil is one patch, into one where the foil is now split in two patches? i.e. What do I put in patchMap or cuttingPatches? Thanks Nick |
Did you try to run mapFields without the -consistent flag?
And maybe in the mapFieldsDict you need to put Code:
patchMap |
Thanks Bernhard
I'll try that. I didn't use -consistent but had other options flagged. I think I'm ok with mapFields except for the ..Dict part... Nick |
