Free surface comes above the hull of the ship |
September 4, 2014, 00:08 |
Sachin
Rep Power: 11 |
I have been working with a hull in Open foam. Iam using LTSInterfoam for the simulation.I was able to mesh the hull using snappyhexmesh. and was able to simulate the flow.
But when i looked at the result it seems wierd. The free surface comes above the hull. the ship virtually sinks in the sea. I have used similar settings as given in the wigley hull tutorial. My speed is 15 knots (7.716 m/s). I have attached the results here: 1) the starting stage. red portion water. blue portion air 2) After 100 iterations. 3) after 12000 iterations. Now i have completed more than 50000 iterations. still the free surface is above the hull. Could anyone help me out with this. what could be the possible reasons??? Iam using openFoam 2.10 |
[snappyHexMesh] Mesh around ship with appropriate free surface refinement | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 46 | October 4, 2019 07:28 |
free surface modelling using VOF | sci | Main CFD Forum | 10 | August 29, 2012 07:43 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
Free surface problem: hull mesh questions | albertofast | OpenFOAM | 2 | December 15, 2010 19:50 |
viscous free surface flow past a ship hull | lololo | Main CFD Forum | 0 | June 12, 2002 23:02 |
