December 15, 2014, 14:30 |
using chemkin
Josh Dawson
Rep Power: 11 |
Hello everyone! I'm attempting to use chemkin but I'm getting the following error:
jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : blockMesh Date : Dec 15 2014 Time : 13:23:09 Host : "jmdag1981-Gazelle-Professional" PID : 5050 Case : /home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 10 Number of boundary faces : 40 Number of defined boundary faces : 40 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 0.46 Block 0 cell size : i : 0.00248768 .. 0.000497535 j : 0.000685672 .. 0.00205702 k : 0.0046 .. 0.0046 Block 1 cell size : i : 0.00129373 .. 0.00129373 j : 0.000685672 .. 0.00205702 k : 0.0046 .. 0.0046 Block 2 cell size : i : 0.00126691 .. 0.00190036 j : 0.000533293 .. 0.00159988 k : 0.0046 .. 0.0046 Block 3 cell size : i : 0.00108267 .. 0.00216534 j : 0.000736823 .. 0.000736823 k : 0.0046 .. 0.0046 Block 4 cell size : i : 0.00108267 .. 0.00216534 j : 0.00100004 .. 0.00100004 k : 0.0046 .. 0.0046 Block 5 cell size : i : 0.00043858 .. 0.00131574 j : 0.00100004 .. 0.00100004 k : 0.0046 .. 0.0046 Block 6 cell size : i : 0.000254255 .. 0.000762764 j : 0.000533293 .. 0.00159988 k : 0.0046 .. 0.0046 Block 7 cell size : i : 0.000254255 .. 0.000762764 j : 0.00050048 .. 0.00050048 k : 0.0046 .. 0.0046 Block 8 cell size : i : 0.000254255 .. 0.000762764 j : 0.000736823 .. 0.000736823 k : 0.0046 .. 0.0046 Block 9 cell size : i : 0.000254255 .. 0.000762764 j : 0.00100004 .. 0.00100004 k : 0.0046 .. 0.0046 Adding cell zones 0 zoneZero 1 zoneOne 2 zoneTwo 3 zoneThree 4 zoneFour 5 zoneFive 6 zoneNine 7 zoneEight 8 zoneSeven 9 zoneSix Writing cell zones as cellSets Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (0 0 -0.0023) (0.500002 0.089999 0.0023) nPoints: 123102 nCells: 60634 nFaces: 243452 nInternalFaces: 120352 ---------------- Patches ---------------- patch 0 (start: 120352 size: 72) name: inletLeftBoundaryZoneZero patch 1 (start: 120424 size: 208) name: fixedWallsTopBoundaryZoneZero_ZoneTwo patch 2 (start: 120632 size: 20) name: symmetryPlaneBottomBoundaryZoneZero patch 3 (start: 120652 size: 60) name: wedgeFaceBottomBoundaryZoneOne patch 4 (start: 120712 size: 128) name: detonationTubeCasingBottomBoundaryZoneTwo patch 5 (start: 120840 size: 2) name: backFaceDetonationTubeCasingLeftBoundaryZoneEight patch 6 (start: 120842 size: 50) name: fixedWallInitiatorTubeTopBoundaryZoneFive patch 7 (start: 120892 size: 5) name: fixedWallInitiatorTubeLeftBoundaryZoneThree patch 8 (start: 120897 size: 50) name: symmetryPlaneInitiatorTubeBottomBoundaryZoneFive patch 9 (start: 120947 size: 128) name: fixedWallDetonationTubeTopBoundaryZoneThree patch 10 (start: 121075 size: 19) name: fixedWallDetonationTubeLeftBoundaryZoneThree patch 11 (start: 121094 size: 128) name: symmetryPlaneDetonationTubeBottomBoundaryZoneFour patch 12 (start: 121222 size: 98) name: outletRightBoundaryZoneSix_ZoneNine patch 13 (start: 121320 size: 432) name: fixedWallsTopBoundaryZoneNine patch 14 (start: 121752 size: 432) name: symmetryPlaneBottomBoundaryZoneSix patch 15 (start: 122184 size: 121268) name: frontAndBack End jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ setFields /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : setFields Date : Dec 15 2014 Time : 13:23:16 Host : "jmdag1981-Gazelle-Professional" PID : 5052 Case : /home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading setFieldsDict Setting field region values Adding all cells of cellZone zoneFive ... Found matching zone zoneFive with 250 cells. Setting internal values of volScalarField H2 Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Setting internal values of volVectorField U Adding all cells of cellZone zoneFour ... Found matching zone zoneFour with 640 cells. Setting internal values of volScalarField H2 Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Setting internal values of volVectorField U Adding all cells of cellZone zoneThree ... Found matching zone zoneThree with 2432 cells. Setting internal values of volScalarField H2 Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Setting internal values of volVectorField U Adding all cells of cellZone zoneZero ... Found matching zone zoneZero with 1440 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneOne ... Found matching zone zoneOne with 4320 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneTwo ... Found matching zone zoneTwo with 9216 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneNine ... Found matching zone zoneNine with 31104 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneEight ... Found matching zone zoneEight with 864 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneSeven ... Found matching zone zoneSeven with 8208 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 Adding all cells of cellZone zoneSix ... Found matching zone zoneSix with 2160 cells. Setting internal values of volScalarField O2 Setting internal values of volScalarField N2 End jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ reactingFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : reactingFoam Date : Dec 15 2014 Time : 13:23:31 Host : "jmdag1981-Gazelle-Professional" PID : 5053 Case : /home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating reaction model Selecting combustion model laminar<psiChemistryCombustion> Selecting chemistry type { chemistrySolver ode; chemistryThermo psi; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleInternalEnergy; equationOfState perfectGas; specie specie; } Selecting chemistryReader chemkinReader --> FOAM FATAL ERROR: Unknown chemistryReader type chemkinReader Valid chemistryReader types are: 1(foamChemistryReader) From function chemistryReader::New(const dictionary&, speciesTable&) in file lnInclude/chemistryReader.C at line 55. FOAM exiting Not sure what I'm doing incorrectly. I've got a chem.inp and therm.dat file respectively in a chemkin folder. I've run through tutorials and searched on this forum but can't find anything regarding this error. Most likely it's an easy fix, I wouldn't be shocked if I am overlooking something very simple. Certainly possible I am being a complete bonehead here! Any help would be greatly appreciated! |
December 15, 2014, 16:38 |
Josh Dawson
Rep Power: 11 |
Can anyone help me? I'm not sure if I am posting these questions correctly, maybe there is something else I am doing incorrectly...but I am not getting any response. Even if someone doesn't have the time to give a complete answser, at least a nudge in the right direction maybe? Thanks in advance!
March 8, 2016, 22:38 |
Thien Xuan Dinh
Rep Power: 11 |
Hi
It is to late, but please check energy option |
chemistryreader, chemkinreader |
how to find distribution field of reaction rates when CHEMKIN is enabled? | EdgarasM | FLUENT | 1 | February 18, 2019 09:41 |
creating PDF Table from imported chemkin files | idomeneo | FLUENT | 1 | November 2, 2016 05:23 |
Chemkin - Detonation | shrikant96 | Main CFD Forum | 2 | July 19, 2016 04:11 |
Chemkin Library (CKLIB) | juzer_700 | OpenFOAM Programming & Development | 0 | February 20, 2013 00:41 |
Question on CHEMKIN INTERFACE | Rui Yang | Phoenics | 7 | January 30, 2002 04:04 |
