createPatch
Old   January 8, 2015, 09:14
Default createPatch
sammasum
samice2008 is on a distinguished road
Dear Foamers,
Can I create a patch of particular size (particular area) using "createPatch" utility? I have an STL surface mesh and I want to select a specific portion or area of the mesh where I want to apply a fixed gradient boundary condition. Any suggestion on how can I do that? examples with bits of code will be really helpful or some examples where this type of issue has been mentioned will be great.
Many thanks
samice2008 is offline   Reply With Quote
Old   January 10, 2015, 03:11
Nima Samkhaniani
nimasam is on a distinguished road
First you should create a faceSet and faceZone with toposetDict, then apply createPatch to create patch from faceZone
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 12, 2015, 07:03
sammasum
Hi Nimassam,
thanks for your reply. I am working on it as you suggested. will let you know how does it go.
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
[mesh manipulation] cyclic patches with different no. of faces - snappyHexMesh - createPatch KYPCK444 OpenFOAM Meshing & Mesh Conversion 1 September 27, 2013 07:13
Cyclic BCs using createPatch in OF 1.6.x SunnyPP OpenFOAM 2 August 6, 2010 10:21
[Salome] unv mesh corrupted after createPatch maddalena OpenFOAM Meshing & Mesh Conversion 1 February 18, 2010 07:43
[mesh manipulation] CreatePatch after subsetMesh maka OpenFOAM Meshing & Mesh Conversion 2 August 27, 2008 07:28
