Segmentation fault (core dumped)
Old   January 9, 2015, 03:20
Default Segmentation fault (core dumped)
NH1994
NH1994 is on a distinguished road
i have a conjugate heat transfer solver. it is comopiled ok so i make a test case to examine its. this error is created .
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
Build  : 1.6-ext-a0e4ecb4d630
Exec   : ConjugateTwoway
Date   : Jan 09 2015
Time   : 09:44:36
Host   : nima-X550LC
PID    : 3357
Case   : /home/nima/Desktop/Nimaconjugate3/fluid
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
--> FOAM Warning :
    From function IOstream::compressionEnum(const word&)
    in file db/IOstreams/IOstreams/IOstream.C at line 75
    bad compression specifier 'off', using 'uncompressed'
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Reading field B1
Reading field volFracorg
Reading field T
Reading field T
Selecting thermal model constant
Reading coupling properties
Create fluid-to-solid and solid-to-fluid interpolators
Check fluid-to-solid and solid-to-fluid interpolators
Fluid-to-solid face interpolation error: 1.77722e-15
Solid-to-fluid face interpolation error: 1.77722e-15
Reading g
--> FOAM Warning :
    From function Cloud<ParticleType>::initCloud(const bool checkClass)
    in file /opt/OpenFOAM/OpenFOAM-1.6-ext/src/lagrangian/basic/lnInclude/CloudIO.C at line 125
    Cannot read particle positions file
    "/home/nima/Desktop/Nimaconjugate3/fluid/0/lagrangian/defaultCloud"
    assuming the initial cloud contains 0 particles.
expected a [ in dimensionSet
in stream ITstream : /home/nima/Desktop/Nimaconjugate3/fluid/constant/particleProperties::mu0, line 19, IOstream: Version 2.0, format ASCII, line 19, OPENED, GOOD
Starting time loop
Evaluating B
Time = 0.0003
DILUPBiCG:  Solving for T, Initial residual = 1, Final residual = 6.17681e-15, No Iterations 1
 heatFlux solid:0.205097
can you help me to solve this? please
NH1994 is offline   Reply With Quote
Segmentation Fault (Core dumped) sihaqqi OpenFOAM Running, Solving & CFD 16 January 20, 2017 15:02
Segmentation fault (core dumped) NH1994 OpenFOAM Programming & Development 0 January 9, 2015 01:24
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
Segmentation fault (core dumped) in Axial_Rotor_MRF sam.ho OpenFOAM Running, Solving & CFD 0 March 17, 2014 01:42
Segmentation fault (core dumped) when changing pressure BC jptorol OpenFOAM Running, Solving & CFD 0 September 25, 2013 18:05
