Questions concerning cyclicAMI definition
Old   January 28, 2015, 09:39
Default Questions concerning cyclicAMI definition
daniel fernex
fernexda is on a distinguished road
Hi Foamers !
I'm running a simulation using cyclicAMI interface, and I've had a hard time finding information about the different parameters to define the interface...
The AMI is defined as such :
    AMI_1
        type        cyclicAMI;
        neighbourPatch AMI_0;
        transform coincidentFullMatch;
        tolerance   0.0001;
        nFaces 350;
        startFace 396934;
But I couldn't find information concerning the following aspects :
  • transform
what is the difference between noOrdering and coincidentFullMatch ? In what case should either of them be used ?
  • tolerance
What does the tolerance change ? I've run a few simulations changing this parameter without seeing any obvious difference...
If someone has already sorted that out I'd be glad to have some advice !
Regards,
Daniel
fernexda is offline   Reply With Quote
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 08:21
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 15:41
CyclicAMI Boundary Condition CUBoulderPhDStudent OpenFOAM Running, Solving & CFD 0 May 21, 2014 19:34
questions on basic OF definition miles_davis OpenFOAM 0 September 8, 2011 07:55
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
