MRF setup
Hi Folks,
I have a question regarding dynamic parts. I try to simulate the effect of different rotation speeds on particle laden flows. For that I want to rotate a goeometry (here a Rotor called Dynamic) and I think that a MRF is the best (?) for these kinds of problems. Now I have included the MRF setting in snappyHexMesh Code:
refinementSurfaces Code:
MRF Code:
actions I also get this message Code:
--> FOAM FATAL ERROR: One other point is the following: Are the origin coordinates (here in red) the coordinates relative to your rotating frame? MRFSourceCoeffs { origin (0 0 0); All help is welcome. Andreas |
Maybe you have already solved your problem, anyway.... I think the problem is that your ''refinementCylinder'' is not a defined .stl geometry file. That's why it cannot be found. Try to define it among your geometries and maybe it will work. I am having some trouble creating MRF and baffles through SnappyHexMesh as well. I am not really an expert,so if you have solved your problem could you post your SHMDict file please? Thx Cheers! |
