using SetFields with the fieldToCell selection
Like Tree1Likes
  • 1 Post By magga
Old   March 11, 2015, 18:41
Default using SetFields with the fieldToCell selection
Marguerite
magga is on a distinguished road
Hi everyone,
I am trying to set a scalar field T, depending on the value of another scalar field alpha.
I would like T to be zero when alpha<=0.5, and T=1 when alpha>=0.5.
I wanted to use setFields, and select the region to be modified with fieldToCell, however I can't manage to do that .... I don't really know what to write it the setFieldsDict, as most of the examples I found on the wed use boxToCell.
Here is what I tried :
defaultFieldValues
volScalarFieldValue T 0
regions
fieldToCell
field alpha;
min 0;
max 0.5;
volScalarFieldValue T 1
And I receive an error message saying
"attempt to read beyond EOF".
Does anyone knows what it means and how I could fix it ?
Thank you very much for any help !
magga is offline   Reply With Quote
Old   March 12, 2015, 02:53
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Not sure this is the reason but the dictionary of fieldToCell is (taken from topoSetDict example)
source fieldToCell;
sourceInfo
    fieldName   U;      // Note: uses mag(U) since volVectorField
    min         0.1;
    max         0.5;
while you use just "field" label for alpha. Have you tried
fieldToCell
    fieldName alpha;
    min 0;
    max 0.5;
alexeym is offline   Reply With Quote
Old   March 12, 2015, 12:33
Marguerite
Indeed this was half on the error, I had also forgotten the 'fieldValue', before the definition of T=1.
Thank very much you for your help alexeym! (and the link towards toposetdict example)
Old   March 12, 2015, 13:46
Alexey Matveichev
Can you, please, share the example of correct syntax of setFieldsDict entry for reference?
Old   March 12, 2015, 14:50
Marguerite
sure, here is the code that works
defaultFieldValues
regions
    fieldToCell
        fieldName alpha;
		min 0;
		max 0.5;
		fieldValues
            volScalarFieldValue T 0 1
alexeym likes this.
Can run setFields in parallel while decomposed? totalart OpenFOAM Running, Solving & CFD 2 August 21, 2018 00:07
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 14:42
rhoSimplecFoam with setFields sino75 OpenFOAM Pre-Processing 0 March 11, 2015 05:08
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
Problems with the execution of the setFields utility. foamer OpenFOAM Pre-Processing 5 June 3, 2013 13:24
