Advices on meshing for OpenFoam
Old   June 9, 2015, 03:50
Wink Advices on meshing for OpenFoam
James F.
NoradFirst2 is an unknown quantity at this point
Hi Foamers,
I am quite new to CFD, especially with OpenFoam.
My case is 2D and using the buoyantPimpleFoam solver and I would like to know if I should mesh my geometry rather with triangle or quadrangle? Is there any rule about how to decide which one I should use?
Also, on my physic system, I have sharp angles but I know I should put fillets instead. What is the minimum radius to be used? (currently using 0.1 but I choosed a random value...)
Thanks for helping!
NoradFirst2 is offline   Reply With Quote
Old   June 9, 2015, 07:55
Elvis
elvis will become famous soon enough
blockmesh creates "hexahedra" mesh -> good mesh for CFD
there is a tool called polyDualMesh: It is used to generate a “honeycomb” polyhedral mesh from a tetrahedral mesh. “honeycomb” polyhedral mesh -> good mesh for CFD
What tool do you want to use for your meshing?
read
http://openfoamwiki.net/index.php/Sn...als_and_Guides
http://upcommons.upc.edu/pfc/bitstre...9/1/memory.pdf
STUDY OF MESH DEFORMATION FEATURES OF AN OPEN SOURCE
CFD PACKAGE AND APPLICATION TO A GEAR PUMP SIMULATION ->2D mesh with snappyhexmesh
http://www.cfd-online.com/Forums/ope...s-meshers.html
elvis is offline   Reply With Quote
Old   July 1, 2015, 04:50
James F.
Thanks for answering, I am using SALOME to mesh.
Meshing software comparison Wikie Mesh Generation & Pre-Processing 5 September 29, 2014 06:09
[ICEM] Meshing advices needed muketa ANSYS Meshing & Geometry 1 July 10, 2009 09:48
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
