Bondary conditions for heat transfer between two fluid regions
Old   July 10, 2015, 05:49
Default Bondary conditions for heat transfer between two fluid regions
buffi is on a distinguished road
I want to simulate heat transfer between two channel flows which are separated by two walls, like so:
----------------------- cyclic
        fluid A <-
======================= wall
        fluid B ->
        fluid A <-
I guess I need chtMultiRegionSimpleFoam for that, or would a different solver be better suited? The wall can be modeled as infinitely thin, i.e. without any thermal resistance.
The two channels exist as two separate meshes which I have created and tested individually. The meshes match geometrically, but the faces do not align perfectly. Do they have to? My problem is that I don't know how to set up such a coupled case. As far as I understand it, chtMultiRegionSimpleFoam accepts one mesh per region as in
constant/
|-regionA/
| |-polyMesh/
| |- thermophysicalProperties
|-regionB/
| |-polyMesh/
but how am I supposed to couple them? The chtMultiRegionSimpleFoam/heatTransfer tutorial did not enlighten me (and I don't think it is close to what I want to do).
The chtMultiRegionFoam/multiRegionLiquidHeater tutorial seems to be closer, but I don't really understand how the coupling is done. Taking a look at that tutorial's BCs it seems that it is enough to set the patch type to
leftSolid/T:
    leftSolid_to_bottomWater
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 300;
        neighbourFieldName T;
        kappa           solidThermo;
        kappaName       none;
bottomWater/T:
    bottomWater_to_leftSolid
        value           uniform 300;
        kappa           fluidThermo;
        kappaName       none;
So in my case I'd use
regionA/T:
    bottomWall
        value           uniform 300;
        kappa           fluidThermo;
        kappaName       none;
regionB/T:
    topWall
        value           uniform 300;
        kappa           fluidThermo;
        kappaName       none;
and that's it? Again, I don't need any kind of conduction modeling in the wall. If it is that simple I guess that those baffles simply confused me.
buffi is offline   Reply With Quote
Old   July 10, 2015, 08:21
Well chtMultiRegionSimpleFoam is now running, but first I had to couple the regions as described in this thread:
http://www.cfd-online.com/Forums/ope...-boundary.html
That took care of the coupling and also of patches not aligning perfectly. However, convergence is still causing some headache.
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 03:53
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
