July 30, 2015, 16:01 |
How choose my boundary conditions
OSM
Rep Power: 10 |
http://www.cfd-online.com/Forums/ope...d-cooling.html
in this thread i have my answers about the problem witch is : cooling a mother Board contain tow cpus (hot part ) and one source of could air (fan) in one side , so i will use chtMultiRegionSimpleFoam as a solver and Salome as a geometry design tool , i complete with my geometry but it last the meshing and the problem is HOW CHOOSE BOUNDARY CONDITIONS ( inlet , outlet , wall , fixed or moved Wall ?????????) pleas help me !!! |
August 1, 2015, 11:31 |
#2 | |
OSM
Rep Power: 10 |
August 5, 2015, 19:28 |
Rep Power: 11 |
Hi liloM,
I'm a new user of OpenFOAM but as an advice you should first define what kind of heat transfers you want to model, how and where. To simulate a cooling of a motherboard, I guess you should also model an external flow around it. |
August 6, 2015, 03:41 |
Rep Power: 12 |
Give more information about your case, upload a picture of your domain, then we can help you
August 6, 2015, 04:41 |
OSM
Rep Power: 10 |
Thank you seanmike31 and hxaxtma ,
ok for more detail this is a capture from my Salome geometry project |
August 6, 2015, 05:23 |
#6 | |
Rep Power: 12 |
In general it is good to start with the tutorials, there you will learn all the basics
https://openfoamwiki.net/index.php/Contrib/groovyBC |
August 6, 2015, 05:53 |
OSM
Rep Power: 10 |
no i will use a cool air with axial velocity , Thank you but for the cpu in T file should i fix the value ? because when the cool air pass throw it , we need to see that the temperature changes with time .!!!
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
