Non-Uniform Inlet Velocity
Old   August 13, 2015, 10:01
Default Non-Uniform Inlet Velocity
Rodrigo
Rodrigo Correa is on a distinguished road
Dears,
I would like to ask you if it is possible to insert a non-uniform velocity distribution in my inlet patch (for instance from a table as we can do in Star-CCM).
I know that it is possible to change my inlet velocity whenever I wish using ''uniform table'' as you can see below:
INLET
type uniformFixedValue;
uniformValue table
(0 (-3 0 0))
(5E+2 (-3 0 0))
(5.050E+2 (-2 0 0))
(10E+2 (-2 0 0))
(10.050E+2 (-1 0 0))
(1.5E+3 (-1 0 0))
I have my inlet velocity distribution and I'd like to insert that and not a constant value and change that during my simulation.
Thank you for your attention!
Rodrigo Correa
Rodrigo Correa is offline   Reply With Quote
Old   August 23, 2015, 10:32
zhaomajie
mjzhao is on a distinguished road
I think this can help you~
inlet
// type timeVaryingUniformFixedValue;
// type timeVaryingMappedFixedValue;
uniformValue tableFile;
tableFileCoeffs
fileName "$FOAM_CASE/0/intable";
outOfBounds repeat;
mjzhao is offline   Reply With Quote
Old   August 24, 2015, 15:47
Rodrigo
Thank you so much for your reply!!!
I will try to perform your tip!
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Modified pimpleFoam solver to MRFPimpleFoam solver hiuluom OpenFOAM Programming & Development 12 June 14, 2015 22:22
Boundary Conditions MtnRunBeachBum OpenFOAM Pre-Processing 1 April 30, 2015 17:33
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
