unable to set source and target faces in a wedge-like snappyHexMesh grid |
September 4, 2015, 06:29 |
Aljoscha Sander
Rep Power: 12 |
dear Foamers,
I've come across a weird error message: i have a case in which i'm using MRF to simulate the Flow around a propeller blade. in order to reduce grid size i wanted to use cyclic(AMI) boundary conditions and thus subdivide the grid into a wedge like sixth of a tube, where the side cuts of the wedge are connected as cyclics. However, when i'm trying to create the patches using creaPatch, i get this: Code:
AMI: Creating addressing and weights between 20486 source faces and 23761 target faces --> FOAM Warning : From function AMIMethod<SourcePatch, TargetPatch>::checkPatches() in file lnInclude/AMIMethod.C at line 57 Source and target patch bounding boxes are not similar source box span : (0.7 0.216523 0.125023) target box span : (0.7 0.000578346 0.250033) source box : (-0.2 0 -1.35412e-05) (0.5 0.216523 0.12501) target box : (-0.2 -4.26578e-06 -1.35412e-05) (0.5 0.00057408 0.250019) inflated target box : (-0.237166 -0.03717 -0.0371793) (0.537166 0.0377398 0.287185) --> FOAM FATAL ERROR: Unable to set source and target faces best, josch |
October 16, 2019, 16:08 |
Rep Power: 11 |
Hi Josch,
have you solved this problem? I got exactly the same error, and don't know howto solve it |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
