PotentialFoam boundary conditions-Flow around a sphere
Old   October 4, 2015, 14:20
Default PotentialFoam boundary conditions-Flow around a sphere
Kostas_K is on a distinguished road
Hello everyone,
I started using OpenFoam recently and i have run some simulations with solvers like icoFoam, simpleFoam,rhoSimpleFoam, sonicFoam already.
Anyway i was trying to simulate the flow around a sphere for Reynolds numbers from 10 to 150 max using potentialFoam but i stuck.
In the boundary file (i didnt create it) there are two regions: GEOM(type "wall") and FARFIELD(type "wall").
Both of them are spheres. GEOM is the geometry around of which i want to calculate the flow and is located inside the FARFIELD sphere, which constitutes the wider control area (inlet and outlet).
So my question is what kind of boundary conditions would i need for the velocity and pressure in order to caculate the flow for different Reynolds numbers ? Is a turbulence model necessary for better results ?
Kostas_K is offline   Reply With Quote
boundary conditions, flow around a sphere, potential flow
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 12:16
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
