January 8, 2016, 03:24 |
Basic AMI question - interface shape
Anton Kidess
Rep Power: 29 |
I would like to simulate a rotor which is tightly encapsulated by a stator with the shape depicted in the attached image. I'm guessing I can't use a single AMI interface due to the kink. Is that assumption correct? Can I circumvent the problem using two AMI interfaces - one for the top, and one for the bottom part of the rotor?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. Last edited by akidess; January 8, 2016 at 09:08. |
January 8, 2016, 08:40 |
Matvey Kraposhin
Rep Power: 21 |
Sorry, can you show axis of rotation on your sketch?
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
January 8, 2016, 09:10 |
Anton Kidess
Rep Power: 29 |
Yeah, I should have included that I added the rotation axis to the figure. I didn't draw it 100% proper, but it should be symmetric around that axis.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
January 8, 2016, 09:30 |
Matvey Kraposhin
Rep Power: 21 |
Ok, now i see (or i think that i see).
I don't see any barriers to use single AMI interface. After 3 years of experience with AMI, we found next two requirements that should be satisfied: 1) Rotor and Stator surfaces should match each other exactly (at least at the level of CAD geometry) 2) Rotor and stator must be meshed with as much as possible uniform grids with approximately same length of of edges
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
volume conservation and accurate interface shape | Prosper | OpenFOAM Running, Solving & CFD | 9 | May 14, 2015 09:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
