[Sponsors] | |||||
talat gokcer
Rep Power: 11 ![]() |
Hello Everyone,
I want to make a simulation two phase ship flow simulation on OpenFoam. I did my test simulation on OpenFoam DTC tutorial. I generated a mesh on snappyHexMesh and run setFields. My initial free surface condition is not that i want. There are nonsense surface elevations. What shall i do in order to make it better? Thanks |
talat gokcer
talat gokcer
Pascal Balz
Rep Power: 12 ![]() |
this could be a mesh effect. Is your alpha 0.5 contour perfectly flat? Sometimes it can be beneficial to use a small offset in your setFields value, i.e. 0.245 instead of 0.244. If this doesn't work try meshing with high aspect ratio cells (so "flat" cells, as in the DTCHull tutorial) at your water surface. This should yield a better z-wise resolution so that setFields picks the right cells.
Regards, Pascal |
talat gokcer
Hi Pascal,
No, it's my 0.5 alpha contour unfortunately. I'm going to try your advices. However, in high aspect ratios snappyhexmesh is challenge. I should play refinement boxes for that. Thank you |
| Tags |
| freesurface |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| problem of Free surface profile | mina00 | FLOW-3D | 0 | October 20, 2014 17:07 |
| free surface problem with open channel | alidogrul | Fluent Multiphase | 0 | August 26, 2013 15:25 |
| Melting and solidification with free surface problem? | cqlwj123 | CFX | 6 | July 25, 2013 03:46 |
| Stir in a bowl : free surface problem | JohnAB | STAR-CCM+ | 19 | March 8, 2013 14:11 |
| How to plot the wave contour in ship flow (free surface) problem | deddy1973 | CFX | 6 | February 19, 2013 06:49 |
