[Sponsors] | |||||
Property which has different values in some cellZones |
Rep Power: 12 ![]() |
Dear Sir,
I would like to describe a property such that it has different values according to cellZone. For example, a property A is 1000 in the cellZone X, and A is 2000 in the cellZone Y, something like that. Could you teach me how to do? Sincerely, KeiJun |
Rep Power: 17 ![]() |
please have a look at the setFields utility. It allows to initialize fields globally or at different zones. The tool setFields uses topoSetSource internally. You should therefore be able to use the definitions of the cell zones within setFieldsDict in the same manner as within topoSetDict (I'm guessing you used topoSet to define your zones, you did not provide more infos). Hope that helps. Cutter https://github.com/OpenFOAM/OpenFOAM...sing/setFields https://github.com/OpenFOAM/OpenFOAM...lation/topoSet |
Hesam
Hello KeiJun,
For this problem,you can use of funkySetFieldDict utility.With this utility for example you can change temperature field and define special T field with special condition. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Loading Cell Values in Tecplot | P1361 | OpenFOAM Post-Processing | 3 | September 16, 2014 05:02 |
| cell values vs node values | reversemermaid | FLUENT | 0 | March 13, 2014 19:06 |
| strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 13:04 |
| URGENT custom property for UDF | Sandilya Garimella | FLUENT | 0 | May 19, 2008 13:35 |
| Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 06:34 |
