Home > Forums > OpenFOAM Pre-Processing
chtMutiRegionFoam without topoSetDict
Old   February 17, 2016, 01:22
Question chtMutiRegionFoam without topoSetDict
Bibin K.S
bibin.sme is on a distinguished road
Hi dear all,
Can anyone tell me how to create multiRegions
without using in toposetDict in chtMultiRegionFoam. since for complex geometries its had to define regions using topSetDict. can we use Salome software to create mesh by zones then split using splitmeshRegions??
Also regarding the coupled Patch Filed, how to define say an interface mass flux boundary condition if needed.... ???
Bibin
bibin.sme is offline   Reply With Quote
Old   February 17, 2016, 16:05
Joćo Ferreira
jmdf is on a distinguished road
Hi Bibin,
yes there are ways to create multi regions without using topoSet.
One way that I used that works with Salome is to create two meshes (or more, depending on how many regions you have), create the boundary that will be the interface between the regions. After that export and convert it to the openfoam format, run splitMeshRegions and create the interfaces on the boundary file.
There are others/better ways to do this, although I don't have enough experience to give you the best answer. However, I believe snappyHexMesh has ways to do it as well.
jmdf is offline   Reply With Quote
Old   February 18, 2016, 01:35
Bibin K.S
Thank you so much Joćo...
Bibin
Old   May 18, 2017, 18:35
alberto
dewey is on a distinguished road
Hi, i am trying to run a chtMultiRegionFoam, i have 3 bodyes, the fluid pipe, and inside i have 2 obstacles, 1 solid, and one porous.
My mesh was created with ansys and exported, later i used the command
splitMeshRegions -cellZones -overwrite in order to put my 3 domains,
but when create the porous zone, this command create the internal faces as wall, how can avoid this? the fluid flow through the porous media. this 2 walls have to be internal faces
porosity_to_part_4-solid
type mappedWall;
inGroups 1(wall);
nFaces 24192;
startFace 1479713;
sampleMode nearestPatchFace;
sampleRegion part_4-solid;
samplePatch part_4-solid_to_porosity;
dewey is offline   Reply With Quote
Thread Tools
Trackbacks are On
Introducing changeDictionaryDict and topoSetDict files in chtMultiRegionFoam fracasce OpenFOAM Pre-Processing 8 October 28, 2015 05:25
Turbulences from Toposetdict??? Ingenieur5 OpenFOAM Running, Solving & CFD 1 June 23, 2014 11:15
topoSetDict m5m5kh OpenFOAM Meshing & Mesh Conversion 5 November 16, 2013 10:09
topoSetDict samiam1000 OpenFOAM 3 August 23, 2013 08:39
topoSetDict in simpleFOAM Goutam OpenFOAM Running, Solving & CFD 2 August 13, 2012 07:47
