chtMultiRegion for newbie
Like Tree1Likes
  • 1 Post By flanel1988
Old   May 3, 2016, 12:15
Default chtMultiRegion for newbie
flanel
flanel1988 is on a distinguished road
Hes guys!
I'm new at this Forum and I am also new at using OpenFOAM. I went through the tutorials and the OpenFOAM user guide and I took a look at the Plane2D tut for chtMultiRegionSimpleFoam. First I just want to know, what you think is the best solution to solve my problem: I have a nozzle (3D cylinder-like with a hole in the middle, Mesh is no problem) in an engine and I want to determine the temperature on the inside of the nozzle with a given temperature at a certain point outside it, that i can measure (and that I measured allready). I don want to have a flow around respectively in the nozzle, I just want to determine the temperature at the inner wall!
What solver would you guys prefer for this case? chtMulitRegionFoam? ~SimpleFoam? or an entirely different one?
Greetings
flanel1988 is offline   Reply With Quote
Old   May 3, 2016, 14:24
Pedro
pupo is on a distinguished road
If i understand correctly you have a nozzle, with a certain thickness, and you want to measure the temperature on the side opposite to the flow explicitly?
If so, and if this is really necessary I'd say a CHTMultiRegion Problem, perhaps a 2d Wedge case simplification with 3 different regions, is the best choice.
However, If the flow outside the nozzle is not relevant why not do a a simple case with just the inside ( using SimpleFoam ) and calculating the outside temperature manually after the simulation is done? It's way simpler, faster and you will probably get the same results.
Alternatively, if the flow outside the nozzle is relevant but simple (say, a textbook scenario of forced convection by air) you could calculate the heat transfer coefficient in that wall and force it as a boundary condition.
I hope this gives you some options to look for,
Good luck!
pupo is offline   Reply With Quote
Old   May 4, 2016, 03:49
flanel
Yes, that is exactly what I want to do. The pressure inside the nozzle is ~5000Pa and outside is nearly vaccum with ~10Pa.
Thank you for your reply, I will take a closer look!
pupo likes this.
chtMultiRegion + Adaptive Mesh Refinement Dostoyefsky OpenFOAM Programming & Development 2 February 21, 2022 03:16
Temperature is not calculated in modified CHTMultiregion Gennaro OpenFOAM Programming & Development 2 December 18, 2014 12:16
conductivity in chtMultiRegion sven82 OpenFOAM 1 November 19, 2010 06:16
turbulentTemperatureCoupledBaffle in chtMultiRegion stawrogin OpenFOAM 0 August 19, 2010 15:22
Mass transfer and chtmultiregion Bufacchi OpenFOAM Programming & Development 0 August 2, 2010 21:28
