[Sponsors] | |||||
Simulation results as Start conditions for a second one |
Louay
Rep Power: 11 ![]() |
Hi Guys,
i really need your Help ![]() Is it possible in openFOAM to perform a simulation and then use its results as initial conditions for a second one? For example: the first simulation(solved with interFoam) is tank, that has two holes filled up with water. The water is defined as a box inside the Tank in setfieldsDict. This Water should flow from the two holes and met up with the first geometry. can i use the deformed water, that leaves that first geomtry in a second Simulation, in which that water meets another Geometry? i know i can do the both simulations at one step, it would be easier, but i must to split the two geomtries and do this way Thanks in advance
Luca
Hi Louay,
I've got the same problem, did you find a solution for it? Luca
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can not start simulation using previous results | Bruno Machado | Fluent UDF and Scheme Programming | 3 | December 14, 2015 12:16 |
| Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
| Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
| Backup results in steady simulation | Li | CFX | 0 | July 9, 2007 06:39 |
| simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 05:19 |
