Two non-reacting gases.
Old   June 13, 2016, 12:26
Red face Two non-reacting gases.
ktk
karthik
ktk is on a distinguished road
How to model mixing of any two non-reacting gases?
I guess in fluent we can use species transport.
Do we have a solver for it?
ktk is offline   Reply With Quote
Old   June 14, 2016, 07:40
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
The reactingFoam family of solvers with reactions turned off should do the trick.
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 14, 2016, 10:39
ktk
karthik
Thanks for the reply Tom.
But are you sure that it will work??
because i tried switching off reaction and combustion of reactingFoam,
but still results were'nt good enough.
I doubt whether we will have to implement some new mixing model in the reactingFoam..
Old   June 14, 2016, 11:01
Tom Fahner
Well I do not know what is "good enough" for your case. Without reactions you only get species transport, besides the flow, pressure and temperature fields. That is just the equations that are implemented. There is probably some model behind this, which may be different from Fluent's model. You would have to investigate I think.
Regards,
Tom
2D simulation for mixing two non-reacting gases arun.mechie FLUENT 17 August 3, 2016 08:31
why there is no iteration for velocity U in reacting foam? prasa OpenFOAM Running, Solving & CFD 3 February 22, 2016 03:35
simulating two different gases achyutan OpenFOAM Running, Solving & CFD 2 December 31, 2013 04:11
Injecting Two Different Gases ERPLCFD FLUENT 1 October 12, 2013 11:21
[Other] Sphere Reacting Foam zovie OpenFOAM Meshing & Mesh Conversion 0 July 18, 2011 21:41
