convert chemkin file ino format
i download the chemkin file from here for iso-octane
but i can not convert it in OpenFOAM format using chemkinToFoam Quote:
I tried it and was able to solve this error by using THERMO ALL instead of THERMO in Thermodynamic parameters file. But then I am getting another error. Quote:
Hi to all,
I have the same problem. did you solve it? thanks in advance Fabri |
Yes.
I copied all the data from these files to the chemkin files given in one of the the tutorial cases of ChemFoam. Can't think of any reason for this. Hope it works for you as well. Regards! |
1 Attachment(s)
hi guys
if you have this problem, you should change reaction file only. because in new format you should put all of third body reactions at the end of this file. in old format third body reactions are in middle of file. I attach a new format file. |
