Problem with ICEM mesh
Old   July 1, 2016, 05:45
Default Problem with ICEM mesh
Ehsan Asgari
syavash is on a distinguished road
Dear Foamers,
I just wanted to know that is this I that have problems with ICEM meshes when converting to foam or it is a general known issue. I cannot get a clean straight forward solution when importing ICEM meshes. No matter how much I try to improve mesh quality and aspect ratio, etc. I have generated very clean high-quality hexa meshes but OF always bothers me. I guess there are some issues related to numerical precision in the meshes generated in ICEM. I hope someone provide more insight, at least.
Thanks
syavash is offline   Reply With Quote
Old   July 1, 2016, 10:42
Ehsan Asgari
Well, that is not a problem of ICEM .
I used another mesh from Gambit, very similar in terms of ratio and spacing to first ICEM one, and the same problem occurred.
The problem is in velocity field where non-physical reverse flow happens top and bottom of a 2-D circular cylinder, at Re=100 which I anticipate to be able to observe Karmann shedding. Reverse flow region is large initially and becomes smaller as I lower Courant No. It occurs near the separation point, so I guess I should still lower the cell aspect ratio in that region. Currently, I use a mesh with maximum AR of 15, but I am not sure how further I should lower mesh AR in that region.
Any comments is appreciated.
Thanks,
Syavash
Old   July 1, 2016, 10:57
Ehsan Asgari
I have provided two screen shots below, from velocity field, as well as an enlarged view of mesh, the small blue regions top and bottom of the cylinder represent reverse flow that should not be there actually.
Comment plz
Problem with primitives 2D mesh regions in CFX-Pre (ICEM Mesh) Shanaylla CFX 2 August 15, 2016 11:35
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[ICEM] Mesh Extrusion problem in ICEM James Hetfield ANSYS Meshing & Geometry 0 July 8, 2012 15:42
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
