Maximal number of boundary patches
Old   July 12, 2016, 09:22
Default Maximal number of boundary patches
Laurent DASTUGUE
laurentD is on a distinguished road
i will need to define a lot of patches for my model (~1000).
But before to define them, and spend an afetrnoon doing that, i guess there is a maximal limit for this number of patches.
Does anybody know more about such a limit ?
Thanks
Laurent
laurentD is offline   Reply With Quote
Old   July 12, 2016, 09:35
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It is maximum value label type can hold and as
A label is an int32_t or int64_t as specified by the pre-processor macro WM_LABEL_SIZE
and it is 2^(N - 1) - 1.
alexeym is offline   Reply With Quote
Old   July 13, 2016, 09:26
Laurent DASTUGUE
Hi Alexey,
i am not sure to understand your answer.
You are saying that if my machine is a 64bit one,
the maximal number of patches is 2^(64 - 1) - 1 = 9e+18,
And if it is 32 bit one, this limit is : 2^(32 - 1) - 1 = 2e+09 ?
Please confirm this information if it is true.
Thank you very much,
Laurent
Old   July 13, 2016, 13:19
Alexey Matveichev
That is right. For 32-bit integers it is 2147483647, for 64-bit integers it is 9223372036854775807. Patches are stored in the data structure PtrList and its size is stored in the field size_ of type label (https://github.com/OpenFOAM/OpenFOAM.../UList/UList.H).
So theoretically, you could store up to 2^(N - 1) - 1 items in PtrList.
Old   July 18, 2016, 09:14
Laurent DASTUGUE
i have tried to use gmshToFoam with a msh including nearly 800 patch names and it crashes with a fatal error when the patch number pass over 99.
Like if there is a limit fixed to 100...
Anyone know where i can modify it ?
Laurent
Old   July 18, 2016, 09:32
Alexey Matveichev
It would be great to see original output (when gmshToFoam crashes) and test case.
Old   July 18, 2016, 09:34
Laurent DASTUGUE
http://www.cfd-online.com/Forums/ope...tml#post610015
Old   July 18, 2016, 09:37
Alexey Matveichev
And the test case? Crash output looks like corrupted msh file. Surely one can generate msh file with 800 physical groups, yet, it will take time.
Old   July 18, 2016, 09:55
Laurent DASTUGUE
The msh file is too big to be sent...
Have you got a mail adress where i can send it ?
Old   July 18, 2016, 10:46
Laurent DASTUGUE
This is the related part of the msh file :
 2 94 "PEAU_EXT_007_02"
2 95 "PEAU_EXT_007_11"
2 96 "PEAU_EXT_007_08"
2 97 "PEAU_EXT_008_04"
2 98 "PEAU_EXT_008_03"
2 99 "PEAU_EXT_008_06"
2 100 "PEAU_EXT_008_01"
2 101 "PEAU_EXT_008_12"
2 102 "PEAU_EXT_008_07"
Old   July 18, 2016, 11:09
Laurent DASTUGUE
Ok i'm sorry...
i have found what was wrong on the msh file.
When the numbering of the patches pass over 99, the writing format is wrong.
Now my model is working with 1661 patches.
Thank you very much for your help Alexey.
Your remarks have been very helpful to help me to find the problem.
Have a good day.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
