K.H
Rep Power: 11 ![]() |
Hi foamers I would appreciate any kind of help. I am trying to mapfields between to meshes with the same geometry but different number of patches/boundarys. The geometry is just a simple channel and the different number of patches is necessary!
For example Source mesh 1: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 -0.050 0) // 0 (3 -0.05 0) // 1 (0 0.046 0) // 2 (3 0.046 0) // 3 (0 0.5 0) // 4 (3 0.5 0) // 5 (0 0.954 0) // 6 (3 0.954 0) // 7 (0 1.05 0) // 8 (3 1.05 0) // 9 (0 -0.05 1.5) // 10 (3 -0.05 1.5) // 11 (0 0.046 1.5) // 12 (3 0.046 1.5) // 13 (0 0.5 1.5) // 14 (3 0.5 1.5) // 15 (0 0.954 1.5) // 16 (3 0.954 1.5) // 17 (0 1.05 1.5) // 18 (3 1.05 1.5) // 19 ); blocks ( hex (0 1 3 2 10 11 13 12) (250 40 125) simpleGrading (1 1 1) hex (2 3 5 4 12 13 15 14) (250 64 125) simpleGrading (1 6.437913785 1) hex (4 5 7 6 14 15 17 16) (250 64 125) simpleGrading (1 0.15532981 1) hex (6 7 9 8 16 17 19 18) (250 40 125) simpleGrading (1 1 1) ); edges ( ); boundary ( bottomWall { type wall; faces ( (0 1 11 10) ); } topWall { type wall; faces ( (8 18 19 9) ); } sides1 { type cyclic; faces ( (0 2 3 1) (10 11 13 12) ); } sides2 { type cyclic; faces ( (2 4 5 3) (12 13 15 14) ); } sides3 { type cyclic; faces ( (4 6 7 5) (14 15 17 16) ); } sides4 { type cyclic; faces ( (6 8 9 7) (16 17 19 18) ); } inout1 { type cyclic; faces ( (1 3 13 11) (0 10 12 2) ); } inout2 { type cyclic; faces ( (3 5 15 13) (2 12 14 4) ); } inout3 { type cyclic; faces ( (5 7 17 15) (4 14 16 6) ); } inout4 { type cyclic; faces ( (7 9 19 17) (6 16 18 8) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // target mesh: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 -0.05 0) (3 -0.05 0) (3 1.05 0) (0 1.05 0) (0 -0.05 1.5) (3 -0.05 1.5) (3 1.05 1.5) (0 1.05 1.5) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 7 10) simpleGrading (1 1 1) ); edges ( ); boundary ( sides1 { type cyclic; faces ( (0 3 2 1) (4 5 6 7) ); } inout1 { type cyclic; faces ( (0 4 7 3) (2 6 5 1) ); } bottomWall { type wall; faces ( (1 5 4 0) ); } topWall { type wall; faces ( (3 7 6 2) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // I know that I can not use mapFields <source case> -consistent because I have a different number of patches but I do not know how to resolve the problem with mapFieldsdict. Thanks in advance!!!! |
Display Modes | |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
