topoSetDict error
Hello all,
I am a new user of openFoam and I try to construct conjugate heat transfer problems. I have to set different topology with topoSetDict but I get the error: "--> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'actions' on line 19 and ending at line 69" file: /home/khoi/OpenFOAM/khoi-v3.0+/run/cht_firsttry/system/topoSetDict at line 69. From function static void Foam::IOerror::SafeFatalIOError(const char*, const char*, int, const Foam::IOstream&, const Foam::string&) in file lnInclude/IOerror.C at line 131. " I have included the topoSetDict file, could some please help me? Thank you in advance Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
Hello all,
I fixed the problem above, but I got a new one. I can run the toposetDict, then when I do splitMeshregions, OF only detects 1 region. The situation as it should be is a patty region in a column of surrounding air. Can someone help me please? Thanks in advance Code:
