August 11, 2016, 19:04 |
flow over cylinder
jafar
Rep Power: 11 |
Hi
i am working on flow past cylinder with Re=0 ,i attached geometry .there are no require set pressure boundary at AB and BC ,how can i implement it in 0/p?i set it as below but no working fine.please help /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1; boundaryField { left { type symmetryPlane; } right { type fixedValue; value uniform 0; } down { type symmetryPlane; } up { type zeroGradient; } cylinder { type zeroGradient; } frontAndBack { type empty; } } /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { left { type symmetryPlane; } right { type fixedValue; value uniform (0 1 0); } down { type symmetryPlane; } up { type fixedValue; value uniform (0 1 0); } cylinder { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-6; relTol 0; smoother GaussSeidel; nPreSweeps 2; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } U { solver smoothSolver; tolerance 1e-6; relTol 0; smoother GaussSeidel; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefPoint (2,0,0); pRefCell 0; residualControl { p 1e-3; U 1e-4; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; } } Last edited by bagherij; August 12, 2016 at 11:12. |
August 12, 2016, 08:35 |
Rep Power: 11 |
I am not sure what you mean by Re=0. So there is no flow at all? Can please provide an error message or what exactly is not working? |
August 12, 2016, 08:45 |
Rep Power: 11 |
On the right hand side you have a symmetry wall, yet you want a flow perpendicular to it? I do not think thats physically possible. Correct me if I am wrong, by in a symmetry plane the mass-flow should be 0 and thus the stream lines need to parallel to the surface, otherwise you have a line with mass constantly flowing in from both sides. Where is the fluid supposed to go without removing mass or compressing it to infinity?
August 12, 2016, 11:47 |
jafar
Rep Power: 11 |
Dear
there was some mistake in the picture,i changed it. the flow is non-newtonnian (creeping flow like foams , filled polymer solution ) therefore re<<1, i attached the governing equations .the problem considered with two planes of symmetry, hence one quater of the domain is used,also i attached the all domain. Thanks |
August 13, 2016, 04:50 |
Tobias Holzmann
Rep Power: 51 |
Finally it is exact that one here: http://www.holzmann-cfd.de/index.php...gelumstroemung But in your case it is a non-newtonian flow. Based on the tensors and fluid behaviors, maybe you are allowed to simplify the deviatoric stress tensor to get a Poisson equation but maybe it is not possible. Anyway (:
Keep foaming, Tobias Holzmann |
August 13, 2016, 16:59 |
jafar
Rep Power: 11 |
Dear Tobi
I attach the domain ,I dont want to apply pressure boundary condition at AB(up) and BC (right) ,how can i do it in the codes? object p; boundaryField { left { type symmetryPlane; } right { ?????????????what should i write??? } up { ?????????????what should i write??? } . ... |
August 13, 2016, 17:28 |
Tobias Holzmann
Rep Power: 51 |
First guess,
PS: I am not sure if you can simplify the case in that way. It should be wrong if I think about it. You should have 2 symmetryPlanes but could it be that you have 3. ?
openfoam 2.1, pressure boundary, velocity boundary |
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 14:44 |
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low | Scabbard | Main CFD Forum | 21 | June 19, 2018 13:58 |
Flow around cylinder free to rotate | Jonas Holdeman | Main CFD Forum | 5 | August 3, 2015 17:54 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
