Compressible Flat Plate with coupled hydrodynamic/thermal boundary layer
Old   September 14, 2016, 14:45
Default Compressible Flat Plate with coupled hydrodynamic/thermal boundary layer
Obad
Obad is on a distinguished road
Hello, I'm new to OpenFoam and trying to solve the flow over a flat plate for already more than a week...
I want to calculate the compressible flow over a zero pressure gradient heated flat plate. I'm using the rhoCentralFoam solver and my boundary conditions are:
velocity: fixed at inlet, no slip at wall, zero gradient for farfield and outlet
pressure: fixed at inlet and outlet, zero gradient for farfield
temperature: fixed at wall, fixed at farfield, zero gradient at inlet and outlet
If I solve the problem without the heating of the flat plate I get a reasonable result for the hydrodynamic boundary layer. However, when I increase the plate temperature the results for the hydrodynamic BL are messed up and the temperature BL looks reasonable instead...
Since flat plate flow is a standard problem I guess someone of you can help me
Cheers!
Obad is offline   Reply With Quote
Developed turbulent boundary layer simulation on flat plate Turbulent CFX 3 June 8, 2015 19:46
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
zero equation model for flat plate boundary layer Amir Main CFD Forum 4 June 18, 2008 11:16
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
