fixedShearStress OF30.x
Hello everybody,
I am running different ABL simulations on OF30.x. So far I have been using slip and zeroGradient conditions for the top boundary (declared as patch). Now I am trying to adopt the fixedShearStress type as suggested on several articles. Unfortunately terminal comes up with such error: --> FOAM FATAL IO ERROR: Unknown patchField type fixedShearStress for patch type patch What should I do? I am a beginner user of OF, I can't really understand very well what to do. Thank you |
Hi Lolli,
You should add the line below in your controlDict: libs ("libturbulenceDerivedFvPatchFields.so"); Jie |
Hi Jie,
let me first thank you for the answer. Unfortunately seems OF3 doesn't recognise this library. Within TurbulenceModels folder I found derivedFvPatchFields, FixedShearStress is into that. I am using RAS model and into its derivedFvPatchFields it is not included. It's like the presence of RAS doesn't permit to use it. Is there a possibility to use RAS model and at the same time TurbulenceModels/derivedFvPatchFields? Lolli |
