FATAL ERROR: ParaView reader module libraries do not exist
How can I fix this problem?
[ofuser@default cavity]$ paraFoam -case $FOAM_RUN/tutorials/incompressible/icoFo am/cavity/cavity FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders ./Allwclean ./Allwmake |
Hi Francesco,
Did you build paraview from source code, or just install it as indicated? Code:
sudo apt-get install paraviewopenfoam3120 http://www.cfd-online.com/Forums/ope...d-problem.html Regards, Arsalan. |
Thank you. But I have already read this post before. I have already tried to type this command but the result was this:
[ofuser@default ~]$ sudo apt-get install paraviewfoam3120 bash: sudo: command not found |
try to use full path:
/usr/bin/sudo Regards, Arsalan. |
