boxTurb strange error
Old   November 10, 2016, 15:26
Question boxTurb strange error
Sudheer Reddy B
sudheer717 is on a distinguished road
Send a message via Skype™ to sudheer717
Hello Foamers,
I am trying to use boxTurb utility to create turbulence field in my domain. I have generated an uniform mesh with 101 nodes in each direction. So my total number of cells as reported by checkMesh are 1000000 which is what I wanted.
This is the output from checkMesh:
Mesh stats
    faces:            3030000
    internal faces:   2970000
    cells:            1000000
    faces per cell:   6
    boundary patches: 7
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     1000000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
When I run boxTurb, it throws me the following error.
Create mesh for time = 0
Reading field U
Reading boxTurbDict
--> FOAM FATAL ERROR:
number of elements in direction 0 is not a power of 2
    Number of elements in each direction = 3{100}
    From function fft::transform(complexField&, const labelList&, transformDirection)
    in file fft/fft.C at line 58.
FOAM aborting
I have read other posts about this utility, there the error was reported as the user had some grading in the mesh. So, I made the mesh uniform.
Any ideas on what I am missing or doing wrong ?
Thank you
Sudheer
sudheer717 is offline   Reply With Quote
Old   November 13, 2016, 15:52
Sudheer Reddy B
My bad, I misread the information given in the error message. I thought the number of elements should be of form N^2 while it expects them to be of form 2^n.
Now it is clear and resolved.
Old   June 30, 2017, 16:33
Default boxturb
Uyan is on a distinguished road
sudheer,
Do you know what are Ek and k0 , in boxturb utility really means.
I need to make a decaying turbulence in a box with certain integral length scales, how do i relate my known length scales to Ek and k0?
Thanks.
Uyan is offline   Reply With Quote
Old   June 30, 2017, 17:16
Sudheer Reddy B
Hi Uyan,
The constants in the boxturb are Ea and k0. They are used inside Ek.H to evaluate the Turbulence Energy spectra with respect to the wavenumber k.
Ek.H is in OpenFOAM-x.x.x/src/randomProcesses/turbulence/Ek.H
I would recommend you to look at this paper:
Martinez, D.O., Chen, S., Doolen, G.D., Kraichnan, R.H., Wang, L.P. and Zhou, Y., 1997. Energy spectrum in the dissipation range of fluid turbulence. Journal of plasma physics, 57(1), pp.195-201.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
