November 24, 2016, 13:42 |
openfoam wich version use in my case
Eduardo Firvida
Rep Power: 15 |
Hi. I'm working on the turbomachine simulation with openfoam, but I can't decide which version of openfoam to use. What I need is calculate the angular velocitie of my rotation system from its interaction with the fluid. This can be done using 6dof along with AMI to achieve the movement of the mesh or system.
On the other hand at some point I will need to consider the solid part as flexible/deformable body, for that I will need the FSI solver included in the OpenFoam-extend version, which does not appear in versions 4.x . So I don't know if the extended version of openfoam has something like 6dof to combine it with GGI and get the rotational speeds calculated from the interaction of the fluid with the machine. |
December 2, 2016, 02:21 |
Nima Samkhaniani
Rep Power: 24 |
i guess openfoam extended is more suitable. It supports both 6DOF and fluid-solid interaction (FSI)
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
December 2, 2016, 08:46 |
Eduardo Firvida
Rep Power: 15 |
December 3, 2016, 09:03 |
Nima Samkhaniani
Rep Power: 24 |
im not using the latest version 4.x however it is almost similar version 3.0
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Exception en virgule flottante | taalf | OpenFOAM | 4 | January 17, 2011 07:25 |
