MPPIC entries in the kinematicCloudProperties |
January 9, 2017, 10:19 |
Hi everybody,
I want to know the meaning of some MPPIC entries of particleStressModel in the kinematicCloudProperties as: - alphaPacked - (Is this the volume fraction of the particle Phase?) - pSolid (Is this the constant Ps of the Harris and Crighton expression for isotropic solid stress) - beta My second question is where I find the sourcefile of the PlessisMasliyahDrag model - is it somewhere in the Folder of the OpenFOAM Software or where can I check up this ? Thank you in advanced. Regards. |
September 18, 2017, 12:50 |
Saeed
Rep Power: 9 |
Hi fjby
alphapacked is the maximum allowable volume fraction of the particles, that is around 0.68 for spherical particles. pSolid is a constant with units of pressure. its value varies from 10 to 100. Read "An Incompressible Two-Dimensional Multiphase Particle-In-Cell Model for Dense Particle Flows" chapter XIV. also beta is an empirical constant. and to your second question search for the name in openFoam folder or google it. |
September 18, 2017, 12:51 |
Saeed
Rep Power: 9 |
by the way do you know when to use packing, damping and isotropy models?? In tutorial folder different combinations of these models are used for each test case.
[snappyHexMesh] Not all entries in refinementSurfaces dictionary were used | will_ca | OpenFOAM Meshing & Mesh Conversion | 5 | November 4, 2021 21:04 |
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary | Struggle_Achieve | OpenFOAM Pre-Processing | 2 | December 20, 2017 03:58 |
How to divide all entries in 0/p by rho | lentschi | OpenFOAM | 1 | March 16, 2011 13:42 |
Don't know entries in fvScheme: div(phi,nuTilda) and div((nuEff*dev(grad(U).T()))) | idrama | OpenFOAM | 1 | October 27, 2010 12:19 |
Accessing Individual entries in a post register | sdwijeya | STAR-CD | 0 | April 29, 2010 14:18 |
