Error: keyword laplacian(nu,U) is undefined in dictionary
I have just started to learn how to work with openFoam. I am trying to solve a simple case of a flow between two parallel plates following a tutorial. When I try to run icoFoam I get the following error message: Quote:
mizo |
laplacianSchemes |
Hi, I also have the same problem. this is my fvscheme file.
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; } laplacianSchemes { default Gauss linear corrected; laplacian(alphae,e) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } But when I run it with chtMultiRegionFoam it gives me an error as keyword laplacian(alphae,e) is undefined in dictionary "/home/thamasha/OpenFOAM/thamasha -10/run/plane/system/fvSchemes.laplacianSchemes". So I run by correcting alpha to alphae too and when I did it the terminal was disappeared. when I run the program without laplacian(alphae,e) Gauss linear corrected; and with default Gauss linear corrected; only still the terminal disappear. could you please help me to solve this problem |
Did you guys solve it?
Try reading:
https://www.openfoam.com/documentati...erical-schemes Also just copy the scheme OpenFOAM cannot find, paste it into the respective subdicionary and add one of the schemes from the user guide. Otherwise OpenFOAM won't know how to discretize the equations. A much simpler way is yoinking an fVSchemes file from a tutorial that uses your desired solver ;) Best regards, Vinz |
