renumberMesh cause severely non-orthogonal faces
Like Tree2Likes
  • 2 Post By alexeym
Old   February 14, 2017, 09:40
Default renumberMesh cause severely non-orthogonal faces
Yue Wang
popstar0426 is on a distinguished road
Deal all:
I used pointwise 18.0 to generated a structured mesh for an airfoil.
Before the renumberMesh step, checkMesh shows everything OK.
Checking geometry...
Overall domain bounding box (-19.5 -20 0) (40 20 0.01)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-1.56059e-20 1.84567e-20 -1.24096e-14) OK.
Max cell openness = 1.70443e-14 OK.
Max aspect ratio = 769.513 OK.
Minimum face area = 9.93236e-09. Maximum face area = 2.29846. Face area magnitudes OK.
Min volume = 4.96618e-11. Max volume = 0.0114923. Total volume = 22.0781. Cell volumes OK.
Mesh non-orthogonality Max: 17.9459 average: 7.75933
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.461725 OK.
Coupled point location match (average 0) OK
Once the mesh was renumberMeshed, the severely non-orthogonal appeared.
Boundary openness (-4.05965e-20 -9.81742e-21 -6.8402e-15) OK.
Max cell openness = 1.8775e-14 OK.
Max aspect ratio = 769.5 OK.
Minimum face area = 9.93262e-09. Maximum face area = 2.29842. Face area magnitudes OK.
Min volume = 4.96631e-11. Max volume = 0.0114921. Total volume = 22.0781. Cell volumes OK.
Mesh non-orthogonality Max: 86.2438 average: 8.62636
*Number of severely non-orthogonal (> 70 degrees) faces: 700.
<<Writing 700 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.46166 OK.
Coupled point location match (average 0) OK.
How to solve this problem?
Best regards!
Michael
popstar0426 is offline   Reply With Quote
Old   February 14, 2017, 10:57
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
What is your writeFormat and writePrecision?
alexeym is offline   Reply With Quote
Old   February 16, 2017, 11:41
Yue Wang
Originally Posted by alexeym View Post
Dear Alexey:
Do you mean the "writeFormat" and "writePrecision" of pointwise to polyMesh?
I used pointwise to generate a 2d airfoil mesh, and extrude it to 3d with 2 cells in the spanwise direction. Then I set the BCs. Export "CAE" to a polyMesh (openfoam mesh) which can be copied directly to the constant folder.
Or do you mean there is "writeFormat" and "writePrecision" of renumberMesh?
Best regards!
Old   February 16, 2017, 11:57
Alexey Matveichev
I mean writeFormat and writePrecision, which are in your system/controlDict. By default in tutorials it they are usually "ascii" and 6. And if you have mesh with small elements precision 6 is not enough (and this is usual reason for this non-orthogonality issues after renumberMesh - https://bugs.openfoam.org/view.php?id=2228).
randolph and Ramzy1990 like this.
Old   February 17, 2017, 00:09
Yue Wang
Dear Alexey:
Thank you very much.
The problem has been solved.
Best regards!
Old   August 6, 2019, 05:40
Pratyush Kumar
PRATBHARAT is on a distinguished road
Overall domain bounding box (-0.00403 -0.00103 0) (0.00403 0.00103 0.00104)
Boundary openness (8.532656034e-18 -1.332719609e-16 5.504011285e-16) OK.
Max cell openness = 2.2465669e-16 OK.
Max aspect ratio = 14.18900306 OK.
Minimum face area = 5.754273324e-10. Maximum face area = 3.011071157e-08. Face area magnitudes OK.
Min volume = 1.313195917e-14. Max volume = 1.603538315e-12. Total volume = 1.726778556e-08. Cell volumes OK.
Mesh non-orthogonality Max: 75.30929246 average: 17.45011295
*Number of severely non-orthogonal (> 70 degrees) faces: 34.
<<Writing 34 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.7423785989 OK.
I am getting the issue of non orthogonality. I am using ansys workbench for meshing. Can you help me to resolve this issue?
Thanks in advance ..
PRATBHARAT is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
