decomposePar fails "Cannot find patchField entry for maxY" |
March 31, 2017, 20:56 |
Jason Quinn
I've been having difficulty with a simple blockMesh and then decomposePar failing due to a "Cannot find patchField entry for maxY"
I would expect I've setup something wrong but I ran thus file before christmas on the same CFD Direct OF4.1 on AWS and it ran fine. Now I can run blockMesh but when I run decomposePar it fails. I've loaded just the constant and 0 folders and the output to the below dropbox. I'd appreciate any ideas folks have. https://www.dropbox.com/sh/cmrfvkzl8...JjGkQLYla?dl=0 |
April 2, 2017, 08:19 |
Rep Power: 12 |
Hey,
there is a clear inconsistency between the patches you created within blockMesh and the patches you adress in your initial / boundary conditions. For example: you create a patch "maxY" in your blockMeshDict which is not present in your initial / boundary conditions. Besides the structure of your blockMeshDict with the "patches" keyword looks very unfamiliar to me. This could be a source of additional problems so be sure to check the structure of blockMeshDict (for example from tutorials) and correct your blockMeshDict according to that - it should be consistent with the OF version you want to use. No chance that this case ran fine in the past. |
April 4, 2017, 01:07 |
Thanks for that. You are right the b.c.
Jason Quinn
The b.c. files do not line up with the patches. No idea how I made this error. This was working so I must've made a mistake and then archived it as I do have reasonable results from this model - obviously with different b.c. and initial condition files.
Thank you. |
decomposepar, patchfield |
1.5-dev: decomposePar pointDisplacement fails when a globalFaceZone is present | matteoL | OpenFOAM Bugs | 9 | May 5, 2013 05:09 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
Error "cannot find -lz" | athlonshi | OpenFOAM Installation | 2 | September 19, 2010 15:59 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
