Difficulty interpreting errors from checkMesh and pisoFoam |
April 26, 2017, 15:00 |
Guilherme
Rep Power: 10 |
Anyone can help me to understand this erro:
ERRO LOG: https://paste.ubuntu.com/24462211/ I used fluent3DMeshToFoam to convert the mesh. I did not get this error. [Moderator note: added the content of the link below] Code:
@ checkMesh -allTopology -allGeometry /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh -allTopology -allGeometry Date : Apr 26 2017 Time : 15:45:34 Host : "user" PID : xxxx Case : /home/user/OpenFOAM/user-4.1/run/Cylinder_3D_RANS nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 3292200 faces: 9690264 internal faces: 9505584 cells: 3199308 faces per cell: 6 boundary patches: 7 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 3199308 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box inlet 6713 6900 ok (non-closed singly connected) (-10 -5 0) (-10 5 5) front 65292 65844 ok (non-closed singly connected) (-10 -5 0) (10 5 0) outlet 6713 6900 ok (non-closed singly connected) (10 -5 0) (10 5 5) cylinder 11564 11800 ok (non-closed singly connected) (-0.499911 -0.499911 0) (0.499911 0.499911 5) top 14553 14900 ok (non-closed singly connected) (-10 5 0) (10 5 5) bottom 14553 14900 ok (non-closed singly connected) (-10 -5 0) (10 -5 5) back 65292 65844 ok (non-closed singly connected) (-10 -5 5) (10 5 5) Checking geometry... Overall domain bounding box (-10 -5 0) (10 5 5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (9.94425e-16 9.90732e-15 -6.95517e-15) OK. Max cell openness = 5.72257e-16 OK. Max aspect ratio = 102.472 OK. Minimum face area = 1.33069e-05. Maximum face area = 0.0706106. Face area magnitudes OK. Min volume = 1.35784e-06. Max volume = 0.00720516. Total volume = 996.074. Cell volumes OK. Mesh non-orthogonality Max: 43.9434 average: 7.50068 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.714944 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.000998794 0.4362 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 0.999996 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.000123873 average: 1.55057 ***Cells with small determinant (< 0.001) found, number of cells: 1122 <<Writing 1122 under-determined cells to set underdeterminedCells Concave cell check OK. Face interpolation weight : minimum: 0.211939 average: 0.494961 Face interpolation weight check OK. Face volume ratio : minimum: 0.269326 average: 0.981702 Face volume ratio check OK. Failed 1 mesh checks. End Last edited by wyldckat; April 30, 2017 at 10:56. Reason: see "Moderator note:" |
April 27, 2017, 07:55 |
ERRO - pisoFoam
Guilherme
Rep Power: 10 |
Anyone can help me to understand this erro? https://paste.ubuntu.com/24466273/ The checkMesh are 'OK'. Thanks [Moderator note: added the content of the link below] Code:
USER@USER:~/OpenFOAM/USER-4.1/run/Cylinder_3D_RANS$ pisoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : pisoFoam Date : Apr 27 2017 Time : 08:49:13 Host : "USER" PID : 4953 Case : /home/USER/OpenFOAM/USER-4.1/run/Cylinder_3D_RANS nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave bounding k, min: 0 max: 9.228e-08 average: 0 bounding omega, min: 0 max: 0.6 average: 0 kOmegaSSTCoeffs { alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::F2() const at ??:? #6 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::F23() const at ??:? #7 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >, Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correctNut() at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Last edited by wyldckat; April 30, 2017 at 10:57. Reason: see "Moderator note:" |
April 27, 2017, 08:34 |
#3 | |
Uwe Pilz
Rep Power: 15 |
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 27, 2017, 17:52 |
Joshua
Rep Power: 9 |
gu1,
Please post what your boundary conditions are in your 0 folder. Joshua Last edited by Joshua14; April 27, 2017 at 18:56. |
April 29, 2017, 08:30 |
Good Morning
Guilherme
Rep Power: 10 |
I solved the problem, did a troubleshoting and understood that thanks to "sigFpe", some of the variables were being divided by zero. It concludes that the internalField for omega was set to zero, so I modified it, solved the problem and started the simulation. |
April 29, 2017, 18:57 |
#6 | |
khedar
Rep Power: 9 |
Last edited by wyldckat; April 30, 2017 at 10:53. Reason: Add quote for the previous post, because the two posts will be merged with the main thread on this topic |
April 30, 2017, 11:49 |
Guilherme
Rep Power: 10 |
April 30, 2017, 13:02 |
khedar
Rep Power: 9 |
This allows you to have a look(visually in paraview) at the cells/faces for which checkMesh is reporting an error. With this knowledge, you can proceed further in tracking the problem, which most probably might have come during the mesh creation.
Regards, khedar |
Sudden divergence of simulation | KingKraut | OpenFOAM Running, Solving & CFD | 10 | July 24, 2017 02:25 |
Solution divergence in pisoFoam (Co <1) | enoch | OpenFOAM Running, Solving & CFD | 0 | May 16, 2012 21:35 |
