[Sponsors] | |||||
What is the consequence of using a high-Re turbulence model on a low-Re grid |
Yuehan
Rep Power: 15 ![]() |
Hi everybody,
We know that the three major variants of the k-epsilon models, the standard k-epsilon, realizable k-epsilon, and RNG k-epsilon model, are all deemed as high-Re models (correct me if I am wrong here). This means that we typically use them on a high-Re mesh, i.e., having y+ = 30 - 120 approximately, together with wall functions. I usually use the following wall functions in OpenFOAM: Code:
k: kqRWallFunction epsilon: epsilonWallFunction nut/mut: nutkWallFunction/mutkWallFunction However, what is the consequence if I use high-Re models on a low-Re mesh, i.e., having y+ = 1 approximately? Does this negatively or positively impact the accuracy of the results? In addition, what types of wall functions (or boundary conditions) should be used when applying high-Re models to low-Re grids? Should I use the following: Code:
k: kLowReWallFucntion epsilon: epsilonLowReWallFunction nut/mut: nutLowReWallFunction/mutLowReWallFunction https://bugs.openfoam.org/view.php?id=1852 So what type of boundary conditions should be used to replace 'epsilonLowReWallFunction'? Thank you. |
Uwe Pilz
Rep Power: 16 ![]() |
As far as I understand this: If you use the wall function at a fine mesh the wall functions will be replaced more and more with the "real" thing. You will mention that k and epsilon will get lower and therewith get more and more out of function.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Yuehan
Many thanks! So you think that using high-Re models on low-Re grids with wall functions wil not negatively affect the accuracy?
Uwe Pilz
If you don't use wall functions, there should be no negative effects.
Yuehan
Uwe Pilz
Don't use walls, use patches. If the solver requires wall function you may choose any of them. They don't matter.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
| Launder Shrma Low Reynolds turbulence model case setup | sivakumar | OpenFOAM Pre-Processing | 3 | September 14, 2013 09:20 |
| Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
| Reynolds transport, turbulence model, etc | Beginner | Main CFD Forum | 1 | January 7, 2009 06:36 |
| turbulence model for low Reynolds Number | Muhammad Shakaib | FLUENT | 0 | July 3, 2006 09:03 |
