Creating baffles in foam-extend
1 Attachment(s)
I am currently working on a three-dimensional channel flow problem with a thin structure, which is finally intended to be integrated into an FSI simulation (that's why I need 0/motionU and constant/dynamicMeshDict).
The thin structure should be located at the face where block 0 and block 2 of my blockMeshDict intersect. Since the structure is very thin, I want to use createBaffles to convert internal faces into a boundary such that I am able to address the two sides of the thin structure separately (such that I am able to request pressure, for example, in the FSI calculation later on). My workflow for this is as follows: Code:
m4 constant/polyMesh/blockMeshDict.m4 > constant/polyMesh/blockMeshDict Code:
faceSet fsBaffleLeft new cellToFace block0 all |
Creating interface in FE-4.0
Hey Marcel,
did you solve the problem? I am sorry to come up as a thread necromancer, but I'm struggeling with the same problem. I'm a foam-newbie and work also on a FSI-case (Foam-Extend 4.0). Thereby I want to analyze the heave-movement of a floating object in a wave tank. So I want to insert this object as a patch with a wall-bc into an internal part of the pre-meshed domain. I went as following: -Meshing with blockMesh -define cellSet "c0" with the geometrie of the floating Object -define a faceSet "interface_zone" out of c0 (just all sides) -create cellZones -replace pre-defined empty interface-patch with new patch (createBaffles interface_zone interface -overwrite) Unfortunately this is not working, coming up with the following checkMesh-log Code:
Create time What am I doing wrong and how is the best-practice-way of getting this solved in foam-extend? Btw. do I have to go with subsetMesh? I would be very happy if you, or anyone in the community could help me with this . Thanks in advance, Henning |
