May 28, 2017, 18:57 |
Using AMI without multi-region meshing
Rep Power: 24 |
Hello folks,
I would like to use the AMI on a different mesh setup than all of the tutorials. For complex geometries I find that the multi-region meshing feature of snappyHexMesh is really unreliable. As an alternative, I mesh each region independently and combine them later. The trouble here is, from what I can tell, the AMI setup using createBaffles can only be done with a conformal interface. The tutorials will split the baffles into two sides using mergeOrSplitBaffles after creating them. But for me, they are already split - but the createBaffles dictionary doesn't allow me to specify two faceZones, one for each side of the interface. So how would I get around this? Anyone done something like this before? |
June 1, 2017, 01:43 |
Rep Power: 24 |
Solution is easy, just make two AMIs and tell them they're each other's neighbor. Assign the slaves a dummy patch and it works.
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Suggestions for a multi region conjugate heat transfer problem | maddalena | OpenFOAM | 14 | September 4, 2013 18:03 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
