Problem with viscosity
Like Tree1Likes
  • 1 Post By piu58
Old   July 2, 2017, 14:57
Default Problem with viscosity
IvánFB
ivanfb95 is on a distinguished road
I'm trying to run Ahmed body 2D case. I have a 3 million Reynolds number and I have used simpleFoam and pimpleFoam solver.
I need a viscosity of 15e-6 and when I use it I get this error: mpirun noticed that process rank 4 with PID 26165 on node ivan-Lenovo-G510 exited on signal 8 (Floating point exception).
When I use a lower viscosity there isn't any error.
Anybody can help me?
Thanks.
ivanfb95 is offline   Reply With Quote
Old   July 3, 2017, 00:38
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
If you increase the Reynolds number wth the viscosity (which is normally the case) I would first try to lower the time step with increasing Re.
ivanfb95 likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 3, 2017, 05:11
IvánFB
You are right but I tried with very low times step and the error continues.
Can be a mesh problem?
Old   July 3, 2017, 08:16
piu58's Avatar
Uwe Pilz
It is always a good idea to have a look at the mesh. Another problem may rise form incorrect boundary conditions.
I would check it the following way:
- Let OF calculate a simulation with a quite high Re, which doesn't crash
- Look at the result (p and U) with paraFoam. Look whether you find regions which look strange
- Think what may be the reason, mesh or b.c.
Uwe Pilz
Dynamic viscosity and Kinematic viscosity asal FLUENT 7 September 3, 2019 01:25
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
turbulent viscosity problem amr mobarez Main CFD Forum 2 January 11, 2013 15:28
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
